Change 2D environment colours
GKR2023
GKR2023
I was wondering if it is possible to change some colours of the 2D environment.
If I want to select an item you normaly get a dotted coloured line that is good visable. Yet when I try it you almost can't see it.
This is what I see, the line is now better visable when I made the screenshot.
Ciao
Enroc
Yes that is possible, go to the aplication options, and go to the tab colors. In the "in-canvas color scheme" box click on custumize schemes.
then you get the following venster and here you can change pretty much all collors, You'll have to search for the richt element (under Graphical elements) because I don't exactly know what line you're pointing to, but it's bound to be there.
alternativale you could simply select a different scheme altogether
