chamfer on hex part
chamfer on hex part
chamfer on hex part
How do I add a chamfer to the hexagon so it looks right (like a nut)? See the attached pdf file for reference.
JDMather
Extrude circle with taper
or
do the same way as out on the shop floor - Revolve Cut.
Examples to follow...
See Attached example showing both techniques.
Paul-Mason
See the attached this is my method there are probably a lot more.
The file is in 2021 IPT format,
I've got others going back as far as 2016 if you need an example form an earlier version
Hope it's of some help.
Creat the boddyCreat the boddy
 Crate the body on either the X,Y or Z plain, extruded equally in both directions
Creat a construction sketchCreat a construction sketch
 Crate a construction sketch on one of the faces
Creat the revolve cutCreat the revolve cut
Using the project geometry create and revolve chamfer cut
Mirrror, if making a nutMirrror, if making a nut
 Mirror the chamfer cut
Inventor 2026 Pro
HP Z4 G4 workstation
Xeon
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
