Is there a way to not repeat the text entered into a chamfer note if the alternate units is turned on? I am hoping to only show the actual dimension value in the brackets, and not repeat the quantity, tolerance note and other text. Ideally it would read like "2x .127 [.005] MAX EDGE BREAK" (with EDGE BREAK below).
Yes, if you edit the styles on this chamfer dimension and remove the text (i.e. chamfer) from the note, it will not appear.
Save this style to use for other chamfer notes.
The if you RC on the note itself and select "Text" you can add any text you want in the text edit box and it will only appear once.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
The answer is "NO" not without manual work..
There is an option to "group dual values together" which is what you want but that sadly was only enabled for Hole Notes for some silly reason...
