Announcements
Challenging punch - How would you model?
YannickEnrico
YannickEnrico
Hey there.
How would you model these punches on the conical bottom piece?
I get a close enough approximation with sweep using guide rail on the cylindrical sleeve. Just wondering about the conical bottom, because that one doesn't seem to accept similar inputs unless I create a new solid.
Despite having drawn as sheet metal and with a rip, I don't actually look to unfold these pieces.
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2024 Professional
Replies (13)
JDMather
@YannickEnrico
Can you Attach the *.ipt file of your attempt here?
If you don't need Flat Pattern then I would probably model one side and Shell.
YannickEnrico
Here are the parts for relevant geometry.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
cadman777
Not trying to dissuade, but if I made a part with that many features, it would bog my system down so bad that I couldn't work.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
johnsonshiue
Hi Yannick,
I don't see a punchtool workflow in this case. A punchtool has to be place on a 2D sketch on a planar sheet metal face. The face could be unfolded bend, but not on a rolled face.
Many thanks!
Software Test Engineer
YannickEnrico
Hi @johnsonshiue
I am absolutely aware it cannot be unfolded in inventor.
I am trying to model the feature -which is a punch in real life- to have an accurate model for drawings.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
YannickEnrico
@cadman777
Yeah, it's suboptimal, but sometimes one needs a 1:1 accurate model
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
cadman777
I hear ya.
Like Johnson said, you can't punch a non-flat surface.
But you can punch a flat sheet and then roll it.
But if you do, your punches get contorted.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
cadman777
OK, so you want to use it on a punch press.
How will the operator do it?
1. On a flat sheet that gets punched first and then rolled?
2. Or on a rolled&welded cylindrical sheet?
If #1, then will it be one punch at a time or multiple punches simultaneously?
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
cadman777
I'm working in 2010, so can't see your model.
So did it just as a visual.
Find attached one method you can use.
It's a bit tricky, but it simplifies the process a bit.
Picking up on JD's suggestion, you can also make a surface and then Thicken it.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
YannickEnrico
I don't know how it's manufactured since it's something we order from someone else.
I am familiar with the theory of order of operations, but I don't think that will make too much of a difference in this case.
I've been working with Sheet Metal for 10 years and as such I'm quite familiar with laser cutting + press brake.
As such I was looking to expand my horizon on geometry like this + get a better representation than this
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
YannickEnrico
Thanks for your suggestion.
I will try and apply that workflow to the conical bottom
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
YannickEnrico
This got me on the right track - It's also a better solution than the sweep I used.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
YannickEnrico
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
