Chain Dynamic Simulation
aaldanaTJVXH
Message 1 of 13
aaldanaTJVXH
Hi guys. I would like to create a Dynamic Simulation of Hydraulic piston lifting a shaft using a chain transmission similiar to system that is use on forklifts. I'm kinda new in the dynamic simulation area so would like to know some guidelines to create this kind of animation.Image.png
Replies (12)
Message 2 of 13
msansom
You can create the animation by using presentation mode. I've always found it to be rather intuitive. I'd maybe watch a quick video on YouTube to get started. Basically, you'll be "Tweaking" your components to simulate the movements. Each tweak allows you to tell the program how long it should take to move from point A to B (or C, or D...). Just tweak the whole assembly in series and then play the simulation to see if you like it. You can make any adjustments in the area below the workspace. Once you like the timing of everything, you can add in camera movements to highlight specific areas of interest during the video.
It's fun to play with and learn. Your best bet is to just give it a try.
Message 3 of 13
swaltonHCHDL
Are you interested in an animation which just shows the motion of the components?
Or are you interested in a rigid body kinematic study that shows the forces acting on the components over time?
Message 4 of 13
aaldanaTJVXH
Hi swalton thanks for the reply. I,m interested in showing the motion of the components.
Message 5 of 13
aaldanaTJVXH
Hi msansom, I'm looking for tutorials of dynamic simulation. I need to do it with that kind of joint.
Message 6 of 13
JDMather
I would not use Presentation *.ipj for this.
I would use Inventor Studio
or
Dynamic Simulation > Pubish to Studio.
@aaldanaTJVXH
Can you Attach your assembly here?
Do you have the Wasim Younis book?
Message 7 of 13
aaldanaTJVXH
Hi JDMather thanks for the reply, is there any email that i can attach the assembly?
Message 8 of 13
msansom
I suppose that depends on the software available to the user, and what is more familiar to them.
Message 9 of 13
JDMather
@msansom wrote:
I suppose that depends on the software available to the user...
@msansom
>>Inventor Studio<<and Dynamic Simulation are both environments with Inventor.
Message 10 of 13
aaldanaTJVXH
I've attached the assembly here.
Message 11 of 13
msansom
I've never actually noticed that icon before, it's like having a new toy to play with!
Message 12 of 13
aaldanaTJVXH
Hi Mr Mather i attached the assembly
Message 13 of 13
JDMather
@aaldanaTJVXH
An assembly must include parts.
In Inventor parts are in the form of *.ipt files.
Dynamic Simulation is an advanced topic - the user should already be expertly familiar with assembly structure.
