Inventor Forum
Chain Drive Animation
21 REPLIES 21
Message 1 of 22
ASchlaack
1467 Views, 21 Replies
I'm modeling out a steel belt conveyence system and need to aminate it. Steel belted conveyers are ran by sprockets and chain links built into the belt. Can I animate it to actually move? All I can find online thus far are ways to make it appear like it's moving but I need it to actually be able to move as if it were real.
This video is an example of what I mean by only being able to find ways to make it appear it's fully moving:
https://www.youtube.com/watch?v=XMxqJDYzbAM
Aaron
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
21 REPLIES 21
Message 2 of 22
JDMather
in reply to: ASchlaack
@ASchlaack wrote:
... I need it to actually be able to move as if it were real.
Aaron
If  you have Inventor Professional - you could probably do this in Environments>Dynamic Simulation, but things could really bog down if you have too many moving components.
Message 3 of 22
ASchlaack
in reply to: JDMather
Is there other ways besides with Dynamic Solutions? I don't need to to include gravity or load forces, I literally just need all of the links to rotate fully around a few sprockets.
In the video I attached is me using what I wasn't wanting to use. And that would be having it rotate the equivalent of 1 link distance then jumping back to the starting point and repeating that.
https://www.dropbox.com/s/lwyi8xvh591a1sd/2_GEAR.wmv
Aaron Schlaack
Message 4 of 22
mrattray
Why?
Mike (not Matt) Rattray
Message 5 of 22
JDMather
Then only way I know to have parts really go around a path is with Dynamic Simulation.
Message 6 of 22
ASchlaack
in reply to: mrattray
Mike, why what?
Aaron Schlaack
Message 7 of 22
ASchlaack
JDMather, thank you. And assuming that is your file, could you possibly allow me to get a copy of it to look at?
Again, thanks you.
Aaron
Aaron Schlaack
Message 8 of 22
mrattray
Why would you need to animate a steel hinged belt in a "non-fake" manner?
Message 9 of 22
ASchlaack
The company I work for wants to test certain things out that would require me to fully animate this drawing.
Aaron Schlaack
Message 10 of 22
mrattray
Then you'll have to use DS as JD suggested.
Message 11 of 22
ASchlaack
Mike have you got any file examples of using DS for this? If so can you please attach them.
Aaron Schlaack
Message 12 of 22
mrattray
Sorry, I do not.
Message 13 of 22
JDMather
My example comes from this book Amazon
Message 14 of 22
ASchlaack
Where did the video itself come from?
Aaron Schlaack
Message 15 of 22
JDMather
Screen Recording of assembly running on my computer using Autodesk Screencast Recorder software (free).
Screencast Recorder
Dynamic Simulation animations can also be published directly to Inventor Studio for access to all of those camera actions as well.
Message 16 of 22
Hi Aaron,
Sorry for chipping a bit late, Youtube has a lot of tips for animating tracks, but as stated previously, it would make you system Very slow.
But if you want to have a go at making an animation, here’s a quick example of one method (there will be lots of others to try) of how to set a track to follow the path tangentially along the desired path. The sprockets wasn’t added but that should be the easier part ;o)
Hope this helps
Cheers
Mark
Inventor 2014
Message 17 of 22
ASchlaack
Could you please post the file you took the video of though?
Aaron Schlaack
Message 18 of 22
ASchlaack
Thank you Mark!!!!
Aaron Schlaack
Message 19 of 22
ASchlaack
Mark, how did you get it to drive? I see the constrants but i see nothing driving it...
Aaron Schlaack
Message 20 of 22
Hi
Just right click on the blue time line parameter (0mm to 916.322mm) its the loop circumference and set it to 6 seconds.
If you tweek the 916 number you will see how it will end in a different place.
Mark
Technology Administrators
