Chain and sprocket in assembly
I am designing a machine assembly, where I am using chain and sprocket. The chain is fixed at both ends and is on a stationary member. The sprocket is mounted on the moving member, which moves up and down.
How do I constraint the above assembly?
JDMather
I assume your question is really about motion.
Assign Parameter names to the vertical lengths of the chain and Drive or Animate Parameter.
