Chage the default save locaction Inventor
I want to change the default save location from google reseurch I was led to belive that we change this to the >>Fequetly used folders<< however I am asked to make sure this is a subfolder of the projects search path....That I cant find??Naamloos.png
mcgyvr
yes.. It needs to be a folder inside the "location" folder in your project.. So K:\Techniek\Inventor Eurotruss\Project Folder\
"Location" should always be the highest level and everything is stored inside that folder (or in subfolders of that folder)
mdavis22569
Are you talking about where your working on files ....ipt's ect that you are using and creating are saved?
Then you want to do it in your workspace ....
I don't have anything in the Frequently, as that's not where I'm saving it ....
Mike Davis
