Centre Line
Centre Line
You can see centre line with more gaps in the finished drawing. But it is not in my drawing. How to get it?
Replies (9)
Hi fiatnm,
I opened your drawing and was able to produce a line with dashes by re-applying the centerline and stretching it to fit. I do not know what your original problem was. You can get a solid looking line like that from stretching out one of the center mark tendrils. I hope this helps.
Edit: Not sure about the center mark being solid. They have always been solid for me, even in circular patterns like that. I fiddled with it a bit. Sorry, not sure how you are supposed to get dashes there.
2016-04-25 15_59_16-Autodesk Inventor Professional 2015 - [Otiose End Plate with Sigma Clip.idw].png
mdavis22569
You can do as @Anonymous said ... however if you move the view the centerline doesn't move or change
If you do it as I show in the video when you move the video it will change
Mike Davis
You can notice this centre line also dash line. How to make it dash line?
mdavis22569
I don't know ... at least a quick way that I would want my guys to do it.   There is probably a work around but...is it work all the effort for something that isn't that critical and more of aesthetics
It could be a setting they had .... it could be because it was done in an older version and it was possible ...
Mike Davis
JDMather
@mdavis22569 wrote:
...   There is probably a work around but.......
In my opinion the original is not done correctly.
You want to right click on the centerline and click on add dashes. There's another tweak in that same context menu that evens the distribution of dashes out. There is a lot of goodies buried in the RMB!
-Mike
After your advice, I reopened the particular file, what a surprise I saw solid line turned into line with dashes. I don’t know how it happened.
JDMather
To me this looks more aesthetically pleasing.
Are you able to find out the reason from expertise?
