Cascade windows
giUNMZF
Observer
Observer
Cascade windows
giUNMZF
Observer
Observer
I used to be able to cascade windows like this in inventor.
Is this still possible in Inventor 2022?
Now I can only Arrange windows edge to edge.
Fouad-l
Hi @giUNMZF
Ithink it's still posible to arrange windows manually by holding & draging the lower frame of each window.
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
giUNMZF
Observer
Observer
That I can do :-), but they are still only edge to edge.
I would like my windows to be overlapping if possible
Borsht
I hate it when their "enhancements" involve taking away features we have been using for years.  Especially when its a feature used in almost every windows based program.
Thank goodness someone will show up with a workaround to save Autodesk's face.
Inventor 2017
Frederick_Law
Drag the tab with the file name outside IV windows.  Not 100% what you need but closer.
I'll like the Tree in the window also.
Borsht
Thanks, and to build upon that, (get ready for a workaround) since I have dual monitors I found that if I drag the tabs to the other monitor, and then on that monitor, go to the taskbar, RMC, and select Cascade Windows, it makes it look like what I want.  I'm not sure if its functional at this point for what I use it for., and if you have any other windows on that monitor it they get mixed into the cascading.
Inventor 2017
