I am having some trouble to use the extrude feature in an assembly. I can only use it to remove material instead of adding.
The "boolean options" in the extrude menu are not appearing. I need to modify a spur gear made with the Design enviroment in assembly (need to make the hole for the shaft and lighten the body). All 3 of previous extrusions were to remove material.
Thanks in advance,
Jose.
Inventor Professional 2022
