Cant select a closed profile from an AUTOCAD imported file
baliasM74U3
baliasM74U3
Hi All
The attached file has a sketch imported from Autocad. This represents the side view of a tank. The issue is when i try to revolve/extrude it to make a solid model, I the closed aread cannot be selected. I tried to project geometry in sketch ,It didint work as well.
Can some one explain What is wrong in my approach. Please find both attached files Inventor and Autocad 2018
Thanks Basil
johnsonshiue
Hi! Your case is quite similar to the following thread recently discussed.
https://forums.autodesk.com/t5/inventor-forum/insert-dwg-in-sketch-can-t-extrude-no-errors-according...
Please take a look at the experts' suggestions. The dwg file contains small unconstrained segments. You need to either import it again by turning on the option to create end-to-end point constraints. Or, you can use Sketch Doctor to repair the sketch. Or, you simply import it as DWG Underlay and then project it to a sketch.
Many thanks!
Software Test Engineer
JDMather
@baliasM74U3 wrote:
Hi All
The attached file has a sketch imported from Autocad. This represents the side view of a tank. The issue is when i try to revolve/extrude it to make a solid model...
Q1. What are your intended units? How tall should the part be?
Q2. Do you want a Revolve or do you want an Extrude? (Pick one.)
JDMather
@baliasM74U3
Where did you go?
baliasM74U3
My intented unit in mm
The height of the tank will be 700mm
I thought of using half of this sktech to revolve and make the model.
JDMather
The original AutoCAD file is rubbish.
I would use only as reference in recreating proper sketch.
baliasM74U3
Why would you say its rubbish ?  just wanted to learn from you. I received it from the original manufacturers of Scania parts.
