Cannot use a template with model state when creating in place
CattabianiI
Message 1 of 9
CattabianiI
Cannot use a template with model state when creating in place.
It was possible with LoD in 2021.
Replies (8)
Message 2 of 9
Gabriel_Watson
Do you have the latest updates?
In 2022.3 I can. Have you checked your active project file to see if your templates folder path is set correctly?
Message 3 of 9
i.cattabiani
I'm using 2023.2
Message 4 of 9
CattabianiI
had to switch account because video uploading get stuck with this one.
Message 5 of 9
Gabriel_Watson
So, it looks fine to me. Is your question about how to use the template with pre-existing model states that did not show up in this example?
Message 6 of 9
CattabianiI
I want to use a certain template with predefined model states but they do not show up when I use create-in-place command.
Message 7 of 9
CGBenner
@CattabianiI
Hi, just for clarification:  Does the template work if you begin a new part, but NOT create in place?
Chris Benner
Message 8 of 9
CattabianiI
Yes.
Create in place in 2021 with LoD: ok
Create new part in 2023.2 with model state: ok.
Create in place in 2023.2 with the same part with model state: not ok.
Message 9 of 9
johnsonshiue
Hi! I believe this is a limitation. When you create a new part in an active non-Primary Model State. The hosting assembly needs to know the exact file and its active Model State. However, the file is not yet saved. As a result, such template cannot be used.
Many thanks!
Software Test Engineer
