Cannot remove Interoperability Between Autodesk Inventor and Revit
ratija.manzinger
Observer Observer
ratija.manzinger
Observer
Observer
  • Installed Inventor just for a small task
  • Around 15 GB still left on my hard drive
  • Installed Inventor Interoperability with Revit (if I remember correctly it was around 8 GB)
  • After a while I uninstalled Inventor
  • Now I am left with around 6 GB of space on my hard drive
It seems like I am unable to remove some leftover data from Inventor.  I am running low on space, that's how I noticed that something was off.
Any help would be appreciated.
Thanks!
CCarreiras
Hi!
Do an Inventor clean uninstall:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Perform-a-clean-un...
In the control panel check for other apps that could stay after uninstall inventor (that could be connected with other software), but you don't need, ex:
CCarreiras
johnsonshiue
Hi! If the Revit Interop for Inventor does not appear in Control Panel, it means the install could be corrupted. You may need to use Microsoft FixIt to uninstall it.
Many thanks!
Software Test Engineer
