Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Inventor Forum
Cannot read texture image
9 REPLIES 9
Message 1 of 10
5856 Views, 9 Replies
When I start a new document or open a file in Inventor, I get a pop up saying: "Cannot read texture image C:\Useers\public\Documents\Autodesk\Inventor 2011\Textures\Chrome.dds"
 I moved the whole Autodesk file and changed all paths under settings>files in Inventor. The new path to Chrome.dds is C:\Users\Kaj\Documents\Autodesk\Inventor 2011\Textures\Chrome.dds
 Inventor works fine but the pop up is really annoying. What can I do about it?
Thanks in advance.
9 REPLIES 9
Message 2 of 10
Mark_Wigan
where did you say you specified the texture file path?
the setting i know of from memory is found under application options, colours... filename. if you changed it there is it still doing it?
best regards,
- Mark
(Kudo or Tag if helpful - in case it also helps others)
PDSU 2020 Windows 10, 64bit.
Message 3 of 10
I didn't see that one, thank you very much!
Message 4 of 10
in reply to: Mark_Wigan
Can you show me how to do that? I'm constantly experiencing an issue where I keep recieving a message stating "Cannot read texture image"
Message 5 of 10
Solution:
              Go to windows security options and TURN OFF Controlled Folder Access.
steps
-windows security
- virus & threat protection
-under Ransomware protection click "manage ransomware protection"
-Either Turn Off or remove the folder from the list of protected folders.
Message 6 of 10
Hi Mark, I am getting this error as well but do not quite understand your response. Could you state it in simpler, more thorough language? Here are my issues:
Message 7 of 10
-niels-
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 8 of 10
in reply to: -niels-
I don't know where to find Application Options. Do you have any advice for that?
Message 9 of 10
johnsonshiue
Hi! Please go to Tools -> App Options -> Colors.
Many thanks!
Software Test Engineer
Message 10 of 10
this solved my issue!
Thank you
What i did was allow an app to have access to protected folders instead. (found inventor.exe in folder and selected it)
