Inventor Forum
Cannot put radius on half circle
2 REPLIES 2
310 Views, 2 Replies
Hi, I just received a part which I'm making a drawing on. I cannot put a radius on that half circle. What can be the reason?
I attached one screenschot.
Kind regards
Joakim
2 REPLIES 2
Mark.Lancaster
@Anonymous
Its hard to tell by the image (arc looks rough) but is it an actual circle/arc entity?  Can you provide the part so we can review it?   Inventor version too?
Mark Lancaster
TheCADWhisperer
@Anonymouswrote:
.... What can be the reason?
Could be spline curve rather than a true geometric circular arc curve.
If it is a spline  - you can either Retrieve the dimension from the generating sketch or feature
or
start a new sketch in the view
Project Geometry
create new arc overtop the spline (and constrained to the spline)
Exit sketch and then dimension the true arc.
If you can't figure it out - as suggested, attach your files here and end all doubt.
