Cannot figure out how to use fold/bend to bend the sheet metal into a box.
patrykstolinski
patrykstolinski
as the title says - I am currently building myself a box for electronics for a stereo piece using 1.5mm thick sheet metal that'll be cut out on a laser cutter. I have attached the ipt and the folded box image, and I'm pulling my hair out of frustration. I simply don't know how to bend it (I want to bend it in inventor so that when I export face as dxf, it'll have the necessary reliefs and edges and what not). I could probably wing it but I can't guarantee the results will look good.
I have also attached what I'm going for in terms of corners locking together - I will weld it, but first I need to bend the walls 90 degrees. I tried bend part in 3d model, I tried fold with various bendrelief values and different starts to bends, and I get one good edge at most. I'm by no means a professional in Inventor, but I do use it to help me out in my hobbies, and I don't know how to get over that hill.
JDMather
The usual process is to model in finished form and then let Inventor generate the flat pattern.
You know the dimensions as you want it when completed - model that.
JDMather
@patrykstolinski
I left dimensioning to you (See Sketch5) in the Attached file.
patrykstolinski
This is amazing, thank you! I will definitely adjust my workflow to make completed bends first.
JDMather
@patrykstolinski
Double check all of the dimensions that I used - as I wasn't really sure of many of them were what you wanted.
(I only spent 30-40 minutes on this example.)
patrykstolinski
Oh definitely, I started a new project to learn your process instead of using your model. That'll commit it all to my memory. Have a good day.
