Cannot Constrain to 3D Sketch in ASSY?
AlexZW28B
AlexZW28B
Using Inventor 2020.3.2
I am currently working on an assembly, and it consists of many parts with 2D and 3D sketches (contained in parts) that I am using for constraining together along with the physical geometry. I have thus far been able to constrain parts together using 2D sketch geometry - but I am hitting a wall with the 3D geometry. After trying different mates, selection filters, hiding/isolating parts, etc. - thinking Inventor was just not "seeing" the features I was wanting to select - I am now suspicious that this functionality is not likely supported?
Wondering if there is any clarity on whether constraints can be added between a part and a 3D sketch feature in a child component in the assembly. I can currently, with the same part in question, select other geometry in a 2D sketch, but it will not let me select a 3D sketch feature...
Thoughts?
mcgyvr
Assembly constraints to part level 3d sketches are not supported.. 2d part sketches only..
You can however edit the part and add workfeatures (work axis,etc..) to those 3d sketch elements and constrain to those..
AlexZW28B
Well... thanks @mcgyvr I appreciate your response - as depressing as it is... I was hopeful - but not optimistic with this one. It feels very restrictive for a Mechanical Product development software - compared to other programs I have used.
Rant:
During this process of development - I had also found out that you cant create a 3D sketch contained in the assembly... Why? Not sure... but again - I am sure this would be an easy implementation considering the other part files have this functionality... I wish Autodesk would implement more of these simple requests into their software at a faster cadence... and would be easy things to start winning the fringe users back... but oh, well. I will continue my lobbying...
mcgyvr
Like other things in life "If it don't make dollars it don't make sense" and "important to you does not guarantee important to me"... 😁
I've been using Inventor for YEARS and have NEVER created a single 3d sketch let alone constrained to one.. Heck I've never constrained to a 2d sketch either for that matter..  And I very rarely ever hear people talking about doing so too..
Feature (face/edge,etc..) to feature only for me and 99% of the discussions I've seen..
Not sure what you are doing but maybe there is a totally different workflow that is more supported for whatever design process you are doing..
