Cannot change Base QTY to Each
tobias
tobias
I cannot change Base QTY anymore to each.
Normally I pull down on the small square, and change them all to Each.
If I do this now, it looks like Inventor is gonna change them all but when finished nothing has changed.
I just found out that this problem only occurs in "Parts Only".
Thanks.
Tobias
The Netherlands
Inventor Pro 2026, Vault Pro 2026, AutoCad Electrical 2026.
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
johnsonshiue
Hi! I believe the change has to be made in the component file. Open the component file -> Tools -> Doc Settings -> BOM. Change the Base QTY.
Many thanks!
Software Test Engineer
tobias
Hi @johnsonshiue,
Thanks, but your suggestion would mean one by one modifying.
To me it's a mistake in the BOM sinds Version 2025.
Tobias
The Netherlands
johnsonshiue
Hi Tobias,
I am sorry I don't think I understand the issue. If possible, please share an example that illustrates the behavior.
I would like to understand the issue better.
Many thanks!
