Can You define parameter names from 'AddRectangularPattern'?
I've built a model which uses syntax AddRectangularPattern and it works fine.
But, I want to be able to change the dimensions on the output parameters (from AddRectangularPattern) without having to delete and recreate the pattern. (this is bad practice when making drawings).
Is it possible to set the parameter names myself?
or at the very least being able to reset to 'Count up' function on the parameter names, right now the names just keeps ticking upwards (see Picture)parametrar.png
You can name them whatever you want, just click in the cell and overwrite what is there.
Thanks but, I would much rather not have to do any manual work to the
modell.
johnsonshiue
Hi! I am sorry I am not sure I understand the request. These model parameters are associated with the pattern feature. If the feature is deleted, the parameters will be deleted. I guess you are trying to drive the values of these parameters and also keep their names static. If yes, you can create user parameters with the desirable values. Then equate the pattern model parameters to each of the user parameter accordingly. Would it work?
Many thanks!
Let us know how we did on Trustpilot.
Software Test Engineer
Thanks for all replies!
I managed to figure it out.
This is how I first had declared the Row spacing (And all the other relevant parameters for the pattern):
RowSpacing = UserParameter
This resulted in a new parameter with a value, for example: d2513=500 ul.
If I instead declared the RowSpacing like this:
RowSpacing = "UserParameter"
The parameter created from the Pattern actually became d2513=UserParameter
