Inventor Forum
Can't use Involute Splines Design Accelerator on factory iparts/iAssemblies?
2 REPLIES 2
kroachA6Y6L
279 Views, 2 Replies
I'm trying to add an involute spline to the hubs of a large ipart factory part inside a matching iassembly with 8 different versions and have it added to all 8 versions.  Every time I try I get this following two errors.:
1) Cannot create iFeature!
2) Not possible to create hub groove!
The same spline works fine on a standard part/assembly of the same geometry.  The hubs of my 8 versions are all identical (this part of the design doesn't change from size to size).
I have already tried redefining the orientation, which has no effect on these parts. Does anyone know of a workaround to add splines to factory parts?
2 REPLIES 2
johnsonshiue
in reply to: kroachA6Y6L
Hi! Specialized components (Bolted Conn, Cable&Harness, Design Accelerator, Frame Generator, and Tube&Pipe) and iPart/iAssembly/Model State are generally mutually exclusive.
Many thanks!
Software Test Engineer
kroachA6Y6L
in reply to: johnsonshiue
Feature Request then:  Please add that to the error message, something along the lines of:
"Specialized components (Bolted Conn, Cable&Harness, Design Accelerator, Frame Generator, and Tube&Pipe) and iPart/iAssembly/Model State are mutually exclusive"
I could have saved a lot of time if I'd known they were incompatible from the beginning.
Thanks.
Tags (1)
