Can't Select Sketch for Loft
brentonwiberg
brentonwiberg
Please take a look at the video below and the attached file.
I have two sketches that are very simple that I'm trying to loft together, but I can't select them both.  Not sure what the deal is, both are closed loops:
https://www.loom.com/share/ab23f5b320e14a53abe4de798ed97441
gcoombridge
@brentonwiberg I haven't watched your video but can select both and loft to a new solid. Attached file in 2021image.png
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
SharkDesign
Your video doesn't work, you are better off using Autodesk Screencast.
https://knowledge.autodesk.com/community/screencast
  Inventor Certified Professional
JDMather
When using Loft, you can only use one sketch section profile at a time.
The way you have sketch this requires two picks in for each sketch.
Your sketches have two profiles in each sketch - a rectangle and a circle.
When you select the Section, the first pick selects the sketch.
Then because you have two profiles (the rectangle and the circle) you must then make a second pick to select EITHER the rectangle or the circle as your section profile.
Then repeat to Cut the hole.
BTW - you should install the Updates for Inventor 2020.
Double Click on image above for video.  Turn on your sound for audio.
