Can't run fwUI.dll
Can't run fwUI.dll
kbo
Message 1 of 32
Can't run fwUI.dll
kbo
After installing Inventor 2020 on a brand new computer I kept getting the same error message.
Can't run :fwUI.dll
Tried to Repair, Reinstall - reinstall windows etc. but without success.
Finally ended up looking in to the Regional settings.
Removed the check mark from "Beta: Use Unicode UTF-8 for worldwide language support"
And that solved the problem 🙂   -  Damm you Microsoft.....Grrrrr
Replies (31)
Message 21 of 32
-JvdZ-
For those who can't find this check box
Jaap van der Zwan
Consultant Manufacturing at Cadac Group MFG BV | NL
_____________________________________________________________________________...
My Screencasts | My Articles
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Message 22 of 32
I did exactly what you said, but it didn't happen
Message 23 of 32
johnsonshiue
Hi! I guess the issue you are having may not be the same as the original thread. Please start a new thread describing the issue clearly.
Many thanks!
Software Test Engineer
Message 24 of 32
sir can you explain clearly for this error
Message 25 of 32
i am getting an error i.e :
cant load:FwuI.dII
Message 26 of 32
johnsonshiue
Hi! Please read reply #21 and follow the instruction to uncheck the option. If it does not help, please make sure all critical Windows updates are installed and appropriate .Net is enabled (2019 and 2020 need .Net 4.7 and 2021 needs .Net 4.8).
Many thanks!
Message 27 of 32
thanks mate but i changed my computer and downloaded the app on the new one
and it just worked I truly don't know how or why but I dont have the
specifics for the error currently
Message 28 of 32
Hey yagiz whats your dp ? Its important please reply
Message 29 of 32
Just helped an employee with "FwUI.dll" error.
The employee stated that Inventor 2021 worked, but after installing updates, then "FwUI.dll" error started to appear.
First we turned of the beta as suggested, didn't help. We switched system language and restarted, didn't help.
Then I noticed that the initial shortcut was named * - English. Looked at the shortcut properties and saw "/language=ENU" at the end of Target:
When removing that from Target, which equals running Inventor.exe clean from it's location, it worked fine.
Hope that helps somebody.
Message 30 of 32
freesbee
...maybe it's worth to mention: somebody could be in this situation.
Make sure you are not trying to install on any "End Of Service" Win10: if you try to install Inv2020+ on any 1809 or previous edition of win10, you might incur in this problem, and there is not very much you can do to avoid it (none of the tips posted in the previous 29 posts will help you).
Microsoft has decided that Windows10 has only 18 months of life, and like it or not, you need to live with it.
Then if you are very unlucky (as me 😵), and you have to upgrade about 70 workstations running Inventor 2016 on Win10 1809, you will do your homework accurately before proceeding...
Massimo Frison
CAD R&D // PDM Admin · Hekuma GmbH
Message 31 of 32
alessandro_rubbiani
Community Visitor
Community Visitor
I tried that but it would still not work
Message 32 of 32
alessandro_rubbiani
Community Visitor
Community Visitor
how did you clean it all
