Can't remove Suppression from Constraint
Vagulus
Message 1 of 13
Vagulus
I Suppressed a constraint in my project using RMC and
When I try to remove the suppression I RMC on it and get
and I can't unsuppress.  Why, and how do I unsuppress the constraint?
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
Replies (12)
Message 2 of 13
CCarreiras
Hi!
Try to restart inventor, because that is the way to suppress/unsuppress constraints.
CCarreiras
Message 3 of 13
Vagulus
I tried that first up.  Then I re-booted the PC.  Still have the same problem. Smiley Frustrated
Albert Einstein
Message 4 of 13
CCarreiras
This only happens in one particular constraint, or you have that behavior in every one?
CCarreiras
Message 5 of 13
TheCADWhisperer
Attatch your assembly here and end all doubt.
Message 6 of 13
Vagulus
Sorry for the delay but AI simply will not Pack and Go.  I tried running repair but I am not happy with that either.  Anyway, I have zipped the folder - everything - ant attached that.
The file in question is AE-000-0000.iam - it's an assembly largely of assemblies.TheOne-640x458.png
This is the constraint I want to unsuppress - larger piccy attached.  Hope this works okay.
Albert Einstein
Message 7 of 13
WHolzwarth
The assy is not easy to overlook, because of some duplicate files, and missing CC members.
Unsuppressing this constraint (Mate:63) from top level assy fails, but try this:
- Open AE-005-0000.iam
- Expand Relationships
- Unsuppress Mate:63
I could get it back to activity this way.
Additional comment: You're drowning in too many constraints. Building sub-assys and using component patterns reduces them drastically
Walter Holzwarth
Message 8 of 13
Vagulus
Thanks a lot.  That got the system working.  Great relief.
I take your point about many restraints.  I'll have to look in to Component Patterns.  I haven't heard of them.
Albert Einstein
Message 9 of 13
Vagulus
That assembly AE-000-0000.iam was largely composed of sub-assemblies.  I have always thought that a natural progression from individual part to complete assembly.  As for Component Patterns, were you referring to Patterns.png?  I do use these - perhaps not often enough. Certainly, I have not tried that arrowed one.  I'll have a play.
Thanks for making the effort to include the Additional comment.  I don't know anyone else who uses AI.  SWX has a stranglehold wherever I look Smiley Frustrated.  Advice from Senior Players is invaluable.
Albert Einstein
Message 10 of 13
WHolzwarth
You're pointing to Sketch driven pattern. This can be used in special cases, but more common are rectangular or circular patterns.
Let's have a look. Below is AE-005-0000.iam shown in initial state. Relationships are about 1.5x screen height.
But this can be combined to only 3 sub-assys. Now relationsships are much less, and could be compressed still more by combining axial mates and face mates to insert constraints or joints.
At sub-assy level, a rectangular pattern for bolting parts makes sense. Look at the start
And the end. Yet more is possible, if no constraints vs origin planes are used
Walter Holzwarth
Message 11 of 13
Vagulus
Thanks for going to all that trouble.  It made for interesting study. Smiley Very Happy
I had a go at that bearing mount as a subassembly
and my constraints differ a little from yours.
(black arrows) Insert Bearing
(red arrow) Insert Circlip
(orange arrows) Mate the two plates
(green arrows) Bolt, washer, nut
(blue arrow) Replicate bolt, washer, nut
  Some of yours I do not understand:
Aerator_04.jpg(green arrow) How did you insert the nut and the washer at the same time?
(orange arrows) You used two constraints - I inserted the circlip with iMates.
(red arrow) What's this Rigid thing?  Some sort of mate between the bearing plate and the lower plate, but what sort?
Albert Einstein
Message 12 of 13
WHolzwarth
Some answers between the lines (in magenta)
Can be collapsed further to a single Insert
Ok, but would need another angle constraint or a surface mate
Needs 3 Mates, but could be done similar as the circlip, or with a single Rigid Joint. In 2019, there's a new functionality (Insert with rotation lock). In many cases, the parts are aligning very well without an angular setup. Right now, I didn't use that very much, but perhaps it's better using than Rigid.
Basically ok, but rotation still is possible
Yes
You're right. Another insert constraint is needed. I can't see no more, if it was already missing in your original file set
I'm preferring normal constraints, not much experience here with iMates. I used face mate for angular placement
As mentioned above, it's an option for fixing two parts versus one another with only one relationship. Some practicing is needed with using that.
Smiley Wink EOR (End of reply)
Walter Holzwarth
Message 13 of 13
Vagulus
Thanks again.
I found the joint button.  You're right.  There's a bit of practice needed here.
Albert Einstein
