Can't remove COG from assembly model
Message 1 of 13
Hi All,
I have an assembly model that, all of a sudden, continuously displays the COG. I can't switch it off from the assemble and it isn't switch on in the part model:-
Another strange thing is I can't make that part (boiler) switch to invisible. I can make it transparent, delete, etc. but I can't make it invisible in the assembly model! All other parts are working fine and as they should do.
Anyone experienced this before?
Thanks.
Rob
Replies (12)
Message 2 of 13
JDMather
Can you open each one of the files and isolate the problem to one of the part files
or
does it only appear in the assembly?
If it is isolated to the Boiler part file - can you attach that file here?
What happens if you do a Manage>Rebuild All?
Message 3 of 13
It only appears on the Boiler part of the assembly. If I open the boiler part it's not visible and the model functions as normal. I've attached the assemble with just the boiler so you can see.
Rob.
Message 4 of 13
blair
We need the other parts that make up the Assembly besides the boiler.ipt
Delta Tau Chi ΔΤΧ
Message 5 of 13
Hi Blair,
Unfortunately, I don't have the permission from my customer upload the whole assembly. This only seems to be affecting the boiler as I can delete all other parts from the assembly and still can't remove the COG or make it invisible. Is the COG displayed at you end?
Thanks for your help.
Rob
Message 6 of 13
WHolzwarth
That seems to have been an issue with Inventor 2016 and was solved with Update 1.
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Unfortunately it came back again with 2017.
Walter
Walter Holzwarth
Message 7 of 13
mcgyvr
Walter
yup..yup..
Message 8 of 13
Oh no! It only seemed to happen after I did the R2 update! Hope Autodesk put out a fix for this.
Message 9 of 13
Curtis_Waguespack
Hi bobbie.k,
nevermind that is R3 not SP3 Smiley Embarassed
and JDMather points out that you are running Inventor 2017, guess I missed that Smiley Embarassed
There is a SP3:
https://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/inventor-2...
I hope this helps.
Curtis
Message 10 of 13
JDMather
@Curtis_Waguespack wrote:
Hi bobbie.k,
There is a SP3:
@Anonymous is running Inventor 2017.
Message 11 of 13
t_hascj
Hi Rob,
This issue was fixed by cleaning a corrupted data. Probably still exist workflow which created this corruption.
I notified the responsible people about this issue and they will analyze it.
Jaroslav
Message 12 of 13
Hi There,
thanks for your feedback. Lets hope it gets resolved soonSmiley Happy
Rob
Message 13 of 13
Hi All,
This issue has now been moved on to the development team foe there investigation:-
Rob.
