Can't place Angle Dimension
llorden4
Message 1 of 10
llorden4
Either I've got the biggest brain fart going on right now or something very wrong is happening with my Inventor.  I'm attempting to place and Angle Dimension for display between a pair of sketched lines.  It will place angles on a number of edges but not ALL the edges available to me.  Someone save my PC from being slung across the room please, what am I missing or what's another way to get 'er done?!
See attached video.
Autodesk Inventor Certified Professional
Replies (9)
Message 2 of 10
leowarren34
Are the other lines part of a 3d object?
Can you send us the file?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 3 of 10
llorden4
I don't want to because I have to remove all kinds of content from the files due to propriety constraints I have placed on me with my employer and I can't just distribute this stuff around.
Surely you can see from the video I have two non-parallel lines in a single sketch, who cares if the other lines are part of the object or not when they clearly have a relationship to each other?  Attempting to use the Centerline feature also fails to produce an angle dimension between an object edge and the centerline feature.  And how could I get a centerline feature perpendicular to my angled edge without an additional sketch anyway?
Message 4 of 10
johnsonshiue
Hi! I guess the dimension mode is set to True instead of Project. When the dimension mode is set to True, it is measuring the exact angle in 3D. The two lines may not be coplanar and they cannot define an angle.
Right-click on the view -> General dimension type -> select Project. Then it should work.
Many thanks!
Software Test Engineer
Message 5 of 10
llorden4
That got it.  I have no idea how a single sketch can create a non-coplanar instance, but my PC is saved!
Message 6 of 10
mageean_michael
Community Visitor
Community Visitor
I have mine set up as project mode and it will not allow me to put an angular dimension on, I have not been able to add an angle dimension on a drawing between holes on anything for example; the most awkward drawing system I have ever come across?
Message 7 of 10
SBix26
Post a file and images that illustrate the problem; I'm sure someone here can show you how.  And, please tell us what version of Inventor you're using.
Sam B
Inventor Pro 2021.0.1 | Windows 10 Home 1903
LinkedIn
Message 8 of 10
johnsonshiue
Hi Michael,
There should be a logical reason to explain the behavior. Either the edge is not projected straight or the view direction is not perpendicular to the hole. Please share the files here.
Many thanks!
Message 9 of 10
fsdolphin
@johnsonshiue
You saved my day; I didn't know about this option.
Message 10 of 10
fsdolphin
You saved my day; I didn't know about this option. Thanks a lot!
