Hello!
I have a sheetmetal panel with holes in multiple flanges. When I try to edit the hole size I get a 0.0 dia. in the size window and when I type in a size to change it the ok button is grayed out. Stumped!!!!!
File and pdf attached.
Hello!
Solved by JDMather. Go to Solution.
What happens if you go to the Manage tab and select Rebuild All?
"That Worked"
Thanks!
"That Worked"
Thanks!
Woops! I get a database error when I Tryed to save.
Right click on the Flat Pattern node in the browser and delete the Flat Pattern.
Save the file.
Now re-create the Flat Pattern and save again.
BTW - if you go to the Windows Start globe in lower left corner of screen and type Snipping Tool in the Search Programs box - you can start the Windows Snipping Tool for capturing portions of the screen for attaching here as png image file.
Save the file.
Success!! I removed the flat pattern, recreated flat pattern, manage rebuild all, save.
YES!
Thanks JD!
YES!
Thanks JD!
