& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Hi!
I am using the following tutorial:
https://www.youtube.com/watch?v=SKtlNOh_Usc&t=629s
At 10:43 the author creates filliet,
but I receive an error message.
Here is my screen/
s
What do I miss?
The file is attached
Thank you!
I did not open your part or watch the tutorial, but in my experience, I have had success, when I created the fillets individually. Meaning instead of having 4 entities under one fillet, try creating the fillets up to that point, then create the fourth as its own feature. I am guessing you get a preview, but it wont create it?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
I created a section view of your boat and found it is only a surface model. You cannot apply a fillet to a surface edge since it has no mass. Once you have created a solid from this surface, you will probably be able to create the fillet.
John Hackney, Retired
@jhackney1972 wrote:.. You cannot apply a fillet to a surface edge since it has no mass.
Oh, I am pretty sure you can.
How do you account for the several Fillets that are already applied?
I guess I missed that one, sorry!
The issue actually occurs much earlier in the design with non-tangent curves.
You missed a Horizontal constraint in your Sketch3 set at timestep 2:40 in the video. (It appears vertical orientation in the video, but is horizontal on the xyz world.
I suspect that there are probably other errors as well.
You missed an implied parallel in Sketch1.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
