Can`t constrain to center, not possible
In sketch mode I`m trying to constrain a simple model, a finished model that I am supposed to edit to get it constrained right.
All the angles and measures are set up, and the lines are constrained to each other, it doesn`t collaps, but it still moves around on the sketch board. I am trying to get it constrained to center origo. But I have no point or reference there to constrain to, so all green here.....Not one blue line.
Please help
Rob67ert
Hi there and welcome to this forum.
Can you attach you file maybe?
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
TheCADWhisperer
Project Geometry the Origin Center Point and then add Coincident Constraint.
Project file and the parts, it`s part 3 I am trying to constrain, probably simpel but....
mcgyvr
