Hi all, I am a high school student and I have gotten into 3D printing, for which I use inventor. I have been using inventor for almost 3 years, and I got a new PC yesterday, installed and was able to use inventor. Today once i tried to launch inventor it told me that my account trial has expired. I have tried getting a new license but all i receive is "We're sorry we cannot provide you with your license details at this time." If my license has expired, this is very annoying because they are no giving me any information at all that would tell me that it has expired. If not, does anyone know how i can deal with this in order to be be able to use inventor? Thank you so much. 😞
Solved by Xun.Zhang. Go to Solution.
Hello @Anonymous,
Welcome to Inventor community.
Try below solution and hope it helps!
Please run through these steps to resolve the issue.
1. Click on “Already have a License”
3. Select "Run" to set a 30 day Trial
4. When AutoCAD launches and opens, navigate the top-right of the screen select the drop-down triangle next to the User Name to display a drop-down
5. Click “Manage License...” to open the License Manager screen.
6. There is a blue drop down arrow, it will show the Trial information
By the way, Make sure the Autodesk License Service is running, I guess. The problem is, if you try anything to correct the trial, it will invalidate the trial and then it will think it is expired. This will almost certainly not work for you. If a trial license doesn't work, it will basically never work.
