Can inventor Record how many holes in a model
Hi Just a quick question, im wondering if its possible to record the amount of holes in a model for the fabrication and pricing purposes... that i can add to my drawing information ? with out having to count every hole?
thanks
JelteDeJong
The following iLogic rule may help you. (i did not test it extensive so it might have some bugs. Test it your self before using it in production.) I know this will not count holes that are created with a "Extrude" feature. Holes that are made but are pathed (closed) by some other feature will be counted anyway.
    Sub Main()
        Dim numberOfHoles As Integer = 0
        Dim doc As PartDocument = ThisApplication.ActiveDocument
        For Each hole As HoleFeature In doc.ComponentDefinition.Features.HoleFeatures
            numberOfHoles = numberOfHoles + hole.HoleCenterPoints.Count
        Next
        For Each pattern As RectangularPatternFeature In doc.ComponentDefinition.Features.RectangularPatternFeatures
            numberOfHoles = numberOfHoles + holesInObjectCollection(pattern.ParentFeatures, pattern.PatternElements.Count)
        Next
        For Each pattern As CircularPatternFeature In doc.ComponentDefinition.Features.CircularPatternFeatures
        Next
        For Each pattern As MirrorFeature In doc.ComponentDefinition.Features.MirrorFeatures
        Next
        For Each pattern As SketchDrivenPatternFeature In doc.ComponentDefinition.Features.SketchDrivenPatternFeatures
            numberOfHoles = numberOfHoles + holesInObjectCollection(pattern.Definition.ParentFeatures, pattern.PatternElements.Count)
        Next
        MsgBox(numberOfHoles)
    End Sub
    Public Function holesInObjectCollection(objs As ObjectCollection, multiplieBy As Integer)
        For Each Feature As Object In objs
            If (TypeOf Feature Is HoleFeature) Then
                Dim hole As HoleFeature = Feature
                numberOfHoles = numberOfHoles + (hole.HoleCenterPoints.Count * multiplieBy) - 1
            ElseIf (TypeOf Feature Is RectangularPatternFeature) Then
                Dim pattern As RectangularPatternFeature = Feature
                numberOfHoles = numberOfHoles + (holesInObjectCollection(pattern.ParentFeatures, pattern.PatternElements.Count))
            ElseIf (TypeOf Feature Is CircularPatternFeature) Then
                Dim pattern As CircularPatternFeature = Feature
            ElseIf (TypeOf Feature Is MirrorFeature) Then
                Dim pattern As MirrorFeature = Feature
            ElseIf (TypeOf Feature Is SketchDrivenPatternFeature) Then
                Dim pattern As SketchDrivenPatternFeature = Feature
                numberOfHoles = numberOfHoles + (holesInObjectCollection(pattern.Definition.ParentFeatures, pattern.PatternElements.Count))
        Next
        Return numberOfHoles
    End Function
Jelte de Jong
Blog: hjalte.nl - github.com
Hi Thanks i will try this
Jesper_S
Hi.
If you are in a Drawing, why don't you use the hole tables?
It can count the number of holes you have in a certain view.
All you have to do is configure it so it doesn't list All holes and positions.
Try with something with few holes first.
//Jesper
b.mccarthy
Hello.
Is it possible to modify the code to count all holes but parse out each hole type?
I.e., I have an assembly with some holes which are 5/8" clearance holes along with others that are 1/2-13 taps.
Thank you.
