Inventor Forum
Can iLogic apply to other parts in the drawing?
3 REPLIES 3
i_am_fail
202 Views, 3 Replies
If I draw a flat square, and then a flat circle next to it, can I do things using iLogic that will make the two seperate parts interact? such as say 'if the circle contacts the square, then make the square become a circle too' or something like that?
thanks
3 REPLIES 3
mrattray
in reply to: i_am_fail
I'm not sure what your asking but, you can have an assembly level rule that controls it's components based on specified conditions.
i.e.
If distance = 0 then
    parameter("part2:1","param") = someValue
else
   parameter("part2:1","param") = someOtherValue
end if
Mike (not Matt) Rattray
i_am_fail
in reply to: mrattray
I don't understand what you mean
What I'm asking is, can we make iLogic on one part, interact with the iLogic on another part.
So for example if I have a pipe, can I make it so that if anything is penetrating through the pipe it will change color (and notify me)?
Hi i_am_fail,
This link has a rule that will find intersecting parts:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Ilogic-and-analyze-interference/m-p/34...
I hope this helps.
Curtis
