i would like to know if it is possible to add a predisigned table to a Drawning. The fact is that i need to add a table of tolerances to my drawnings, but i don´t need to use it to all of them.
I know how to "call" from Excel, but it is possibe to save tables in Inventor himself, and call it, like a revisión table?
Thank you!
Thank you!
Solved by mdavis22569. Go to Solution.
Why not make them as Sketch symbols and insert them as you would need them ....
basically the same as calling them up from excel
I need to create a tolerance table in my Sketch Symbols. Do I need to draw it line per line, or can I create in in excel and copy/paste the table into Sketch Symbols? Or is there a way to draw a table inside inventor's Sketch Symbols editor?
Hi! You could certainly drawing lines by lines in Sketch Symbol or copy and paste an AutoCAD table to Inventor. Or, you can just use General Table command, instead of Sketch Symbol to do that.
Many thanks!
Many thanks!
