One of our designer has the following problem and perhaps it can be improved in a next Inventor release:
I don't know if it is possible but I would like the tolerance box to resemble the first print screen but calling up a value from the 3D excel file (using iparts)
In the feature control frame, this value is underlined in red:
The goal would be to be able to call a value from the 3D excel file as you do it with the format text option (available on “Dimension”, “text” functions). See the following picture:
Thank you very much,
Cheers,
Sylvain
