Calculate surface area Vba
First I would like to say that my knowledge of VBA coding is limited. That being said I do have some coding experience but I am unfamiliar with some of the concepts of VBA coding and how they interact with inventor files.
Currently I am trying to figure out how to calculate the area of a flat pattern created in an inventor part file and then have that area subtracted from a rectangular boundary box that is dictated by the largest length and largest width of the part file, a picture file is attached for better visualization. This information would then need to be exported to our cost report as a scrap factor.
Attached is our current cost report macro VBA Code as a text file. Which was not written by myself. I was wondering if there was a way to easily implement this idea into the current code? Or would it be best to create another macro?
Any help is much appreciated.
johnsonshiue
Hi! Is this a school project? You may want to discuss with your classmates or teaching assistant first. Let me give you a hint. Inventor sheet metal part has uniform thickness. Volume is part of the physical properties. Surface area (flat pattern area should be computed easily.
Thanks!
Software Test Engineer
This is a project for my workplace. Where we are trying to implement this idea into our already existing software.
So any help would be much appreciated. I just need help on the best location and best way to call out for information for what I am trying to do and how to implement it in the most efficient way into the existing code that I already have. This is a project that I am researching for my company to help alleviate some headaches we have with scrap factors with our plasma table.
PaulMunford
You could do this with iLogic.
You can get the extents and area like this:
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
Would that give you enough to work out the extents area and subtract the face area?
Paul Munford
Technical Onboarding Architect
Linkedin
