Currently studying/practicing developing a flat pattern to create a 4 piece 90 degree elbow.
Just following the instructions in a "pencil and paper" drafting book but using
AutoCAD to automate and speed up the process.
My question - can a flat pattern be created in Inventor without using Sheet Metal or
Tube and Pipe rules (have not studied these two sections very much so far).
Did try a basic Inventor construction on both circular and hexagonal cross section
profiles. Excellent practice on work plane, points, axes but mating faces did not come
out correctly.
A second question - what needs to be done to constrain two circular extrusions along
two faces that are each cut at an angle (say 15 degrees). Attempted to do so but really tough
to align outside surfaces when there are no alignment marks to use.
Thanking all in advance and appreciate any help on the questions.
Andrew
