Hello.
I think there is a bug with the RMB menu position on Browser.
Look at the SS below. It shows my entire screen:
Steps to reproduce the bug:
- Open an Assembly with an Subassembly.
- There is a Folder with some fasteners in the Subassembly ;
- Activate the subassembly;
- RMB on any items inside the folder.
Does it happen on your computer too?
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
Is this based on Inventor 2020? Or another version?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
Hi
The RMB menu shows on my 2020.1. See the attached image.
Could you inform your screen resolution? are you using 4K monitor? Much appreciated if you could provide one video to show your steps, it will help a lot.
Thanks!
Could you inform your screen resolution? 1366 x 768
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
Hi
Thanks for the video!
For R2020, the suggested minimum Display resolution is 1280x1024 (please refer to https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic... )
Yours is smaller than the requirement, so this might be the reason that you see the issue. We will have a try with same resolution and back to you.
To see the context menu with your current display resolution, could you RMB in canvas to see it?
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
Yes, you could select the component from browser, then move your mouse to graphic window, then RMB, the same context menu need show.
Could you please check whether you could see the full list of the context menu?
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
