[Bug] Model state and Positional rep. override interaction edge case
Hi
It seems like there might be a bug that occurs when switching to a model state while in a positional representation with a 'modify' override.
I had a part with an angle which changes depending on the pos. rep., and switching to another model state which has the same constraint and corresponding modification in the pos. rep., still somehow causes the dialog to appear that says the values are mismatched in the model state table; and letting Inventor update the value changes the base pos. rep. value instead, meaning both pos. reps. for the newly-switched-to model state have the altered value (information lost and base pos. rep. overridden).
It seems like it behaves normally until the base pos. rep. values are forked from one another and put into the model states table (i.e. first change the base value of one to generate the column, and then it doesn't matter what it is, even  if you change it back to being the same as the other's).
I've attached files that should replicate all this.
All this seems to me to beg the question: why can base pos. rep. values differ between model states, but modifying overrides in other pos. reps. not? I would understand it working one way or the other. I don't know how other people are using the software, but maybe it would make the most sense if deviations in modify overrides were tracked by the model state table as well.
Anyway, thanks !
johnsonshiue
Hi! I believe this is indeed a bug. But, it should have been fixed on 2022.3 update. Please install 2022.3 update followed by 2022.3.1 update.
Many thanks!
Software Test Engineer
