Bug inside dimension box
sebastien.forman
sebastien.forman
There is a bug when the dimension and the position of the box is save in bad position. There is a ghost clic in this box.
Thank you fort the futur fix.
Curtis_Waguespack
Hi sebastien.forman,
What version of Inventor are you seeing this issue in?
I hope this helps.
Curtis
mcgyvr
This has been reported a few times by other users..
I'm having difficulty locating those posts though..
rhasell
Hi
One observation on how it happens.
To edit a dimension requires a double click (Normally) BUT if the dimension tool is active, it only requires a single click to edit the dimension.
Therefore, the second click will select anything that happens to appear under the cursor at the time.
Very irritating. One option is to move your dimension box out of harms way, so theoretically, you shouldn't accidentally select something. (That's until it fixed)
Reg
2026.1
sebastien.forman
hi guys,
I am using inventor 2017.
Thanks you for your help.
Yes this solution is good of course, this bug is not really a big problem for my job.
I just want to highlight it for having better soft in the futur.
Have a nice day.
Sébastien
