BROWSER DROP DOWN MENU BOTTOM CUT OFF
MikeKovacik4928
Advisor Advisor
MikeKovacik4928
Hi All
My browser drop down menu gets cut off, more the lower down the browser I go.
Is there a way of getting the whole lot to show?
Mike Kovacik
Inventor Pro 2025
kacper.suchomski
Hi
I'm wondering if this might be a graphics/monitor settings issue.
If you point to the bottom items, the context menu displays upwards.
Have you changed any settings on your computer?
Kacper Suchomski
johnsonshiue
Hi! I believe this is related to the display settings. Go to Windows Display settings and select the recommended resolution and scale. Right-click on Inventor desktop icon -> Properties -> Compatibility -> Change High DPI settings -> check both boxes. If you are using dual monitors, make sure the one hosting Inventor is the primary display.
Many thanks!
Software Test Engineer
MikeKovacik4928
Hi Johnson
Have done that, still the same, hasn't made any difference
Regards
Mike Kovacik
johnsonshiue
Hi Mike,
Maybe you want to try using Inventor Reset Utility to reset all settings back to install default. In the meantime, please make sure all the critical Windows updates, the graphics driver, and all the critical PC vendor updates are installed.
Many thanks!
