Browser bar keeps disappearing
SharkDesign
SharkDesign
I have the browser bar on my second monitor and it keeps randomly disappearing and changing into just an x box (the close button) and a tiny tiny window around it.
If I click view > user interface and uncheck then recheck the browser bar box it works fine again.
I assume this is a bug?
Inventor 2015
  Expert Elite
  Inventor Certified Professional
CESAR200
Hello James,
We cannot confirm this is a product issue unless there is a way to reproduce it.  Try this method to restore the browser bar:
1. Close Autodesk Inventor
2. Open the Windows Registry Editor and navigate to the following folder:
   HKEY_CURRENT_USER\Sotware\Autodesk\Inventor\RegistryVersionXX.X\DockingAreasRibbon\BrowserBar\
3. Ensure the value of the dword key named "Visible" is '1' (one)
4. Close the registry editor and restart Inventor
If the problem persists, back-up your customizations and run the Inventor Reset Tool, as described in the article linked below:
   http://knowledge.autodesk.com/article/How-to-use-Inventor-Reset-Utility-to-reset-the-local-environme...
I hope this helps.
Cesar Valencia
Product Support
SharkDesign
dword is set to 1.
Here is a screenshot of the problem too. I've highlighted the browser bar.Capture.PNG
  Expert Elite
