Broken dimension lines
NielsMaas
NielsMaas
Hello everybody,
I'm experiencing the same problem as described in #M543888 but in a complexer way.
I have a drawing with a part that's dimensioned ordinate. Due to a change in the design I had to replace the part with an adapted copy. Most of the dimensions maintain but i had to add a new ordinate set. When i do so, the next thing occurs:
For some reason on the position of the old ordinate set there are hidden objects that disturb the new ordinate set (see red circle). It looks like remainings of the old ordinate set.
Is there a way to get rid of these "blind spots"? I've have seen this behavior in earlier versions of IV but never found a solution to this problem.
Best regards,
Niels Maas
IV 2015 Professional SP1
Dell Precision T3500
Intel Xeon W3670 @3.20GHz
12.00 GB RAM
64 bit Win 7 Pro SP1
NielsMaas
Oh, I missed that one Smiley Embarassed
It's not an explanation for the problem but at least a way to fix it.
Thanks!
No idea what causes the blind spot, but at least it can be fixed.
