Inventor Forum
Break symbol not visible when breaking through open space.
7 REPLIES 7
Message 1 of 8
dave_novak
336 Views, 7 Replies
I have been reproducing this item for years with the ability to place multiple Breaks in a View without a problem. Now the Break Symbols are not visible when cut through open space. Therefore I'm unable to adjust the size of the Break. The only way I have found to be able to adjust the Break is to delete any Cropping from the View if there is any and also remove any Section participation. This will now show the full size of the item being broken. Now the Break Symbols will be visible.
Any help with this issue would be greatly appreciated.
7 REPLIES 7
Message 2 of 8
ldutkaTUZ58
in reply to: dave_novak
What version in use??
Message 3 of 8
dave_novak
Sorry, I'm currently running 2024.
Message 4 of 8
johnsonshiue
Hi! The symbol behavior does not look right to me. If possible, please share the files in zip with me (johnson.shiue@autodesk.com) directly. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
Message 5 of 8
dave_novak
in reply to: johnsonshiue
Hi John,
Thanks for reaching out. I have sent an example showing the issue.
Message 6 of 8
johnsonshiue
Hi Dave,
Unfortunately, I have not received the email from you. Please send it to johnson.shiue@autodesk.com again. I will check my spam folder.
Many thanks!
Message 7 of 8
dave_novak
Hi John, Sorry about that. I tried to send a Zip file that was too large. I was able to reduce the file size and I believe you should receive it soon.
Message 8 of 8
johnsonshiue
Hi Dave,
I still have not received your email and the file. I also checked Spam and Junk folders. Pleas resend it. Or share it on a cloud drive of your choice and grant me (johnson.shiue@autodesk.com) download privilege.
Many thanks!
