Hi Bob,
I know this post is very old but I'm looking to do exactly that. Instead of drawing sketches, adding parameters and export those I would like Inventor to feed me the information it can gather from the model.
As I know nothing of programming I copied the code found in the search but it is giving me an error regarding Sub Main (). As far as writing codes to save this information as user properties I will have to find help for that. For now my question would be how can I fix the code to eliminate the error?
Hello @Anonymous this is Bob from the past... @Anonymous, Bob's account is no longer active and Bob will never response to you.. So don't wait around for an answer..
What code are you even referring to.. Instead of responding to a 13 year old posting, create a new one and shows us the code you copied.. If you copied something that is old/outdated it may no longer work.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Thanks for the advice Mark.
I posted on a few "Bounding/Range Box" subjects today, some much more recent. I am never waiting on a precise person to answer, I know others will eventually read it, exactly as you did
The VBA sample code Bob was talking about last decade is still available in the API help when searching for drawrangebox. But simply copy-pasting it does not work. I know nothing about programming language so I can say what's wrong. Anyhow I was just trying out a few things in order to automate a few steps done manually and will forget about this post.
