Hello Friends,
I am facing small difficulty in inventor in drawing.
I want border along the view . Which I created in sketch mode.(find attached file)
But problem is that whenever I move the view border does not move along with view.(find next attachment)
Is there any other better way to create border along view.
Pls help.
Thanks and Regards,
Datta Indalkar.
Solved by JDMather. Go to Solution.
Your sketch is at the sheet level, not at the view level.
Click on the view - you should see a red boundary around the view.
Do not move the mouse.
Hit S on they keyboard to start a sketch within the view (this isn't really necessary, but having taught hundreds of students this is the best way that I have found to make sure focus isn't lost on the view level).
Dear Mathar,
Thank you very much for your help.
If such small trics available with your forward .
the below point is small but very effective.
With Warm Regard's;
Datta Indalkar
