boolean- cutting sphere
Message 1 of 8
Hi there!
I need to cut sphere from solid,
but inventor sees sphere as a part of the solid,
e.g. I have only one solid and for boolean operation I need two.
This is what I need
and here what I have
My file is attached.
Thanks!
Accepted solutions (3)
Replies (7)
Message 2 of 8
Message 3 of 8
Why not just do a Revolve cut instead of revolve join?
Message 4 of 8
mwighton
Change your Revolve 1 feature from a Join to a Cut.
Edit the feature, the 3 boxes in the middle of the window, the second one down is a cut. select this one and you should get what you are looking for.
Did this post help out? Hope it did.
If so please use the 'Accept as Solution' or 'Kudos' Button below.
God Bless
Mwighton
Message 5 of 8
mwighton
God Bless
Mwighton
Message 6 of 8
JDMather
Note that
Join will preview Green
Cut will preview Red
Intersect will preview Blue
Message 7 of 8
Seems like it would have been a lot easier to do the hole part as one revolve feature. If you want to use the method you're describing though, when you create the sphere, there's 4 options for what to do with your profile in the middle of the dialogue box. There's cut, revolve, intersect, and new solid. Just check new solid....you can also go back and edit the feature to make it a new solid so you don't have to delete or redo anything.
Message 8 of 8
Thank you for all replies!
Each one of them is helpful!
thanks!
