BOM structure for model states
dimamazutaMMJ32
dimamazutaMMJ32
Hello!
I have a problem in model state with suppressed parts. I don`t understand how to exclude suppressed parts from BOM in model states ā„–1 and left them in BOM in model state ā„–2.
Replies (16)
mcgyvr
Sounds like you haven't changed to "Member Scope" and may be set to "Factory Scope"
Press the "Pencil" icon next to the model states folder or select it from the dropdown in the drop down of the author section on the manage tab.
dimamazutaMMJ32
I can suppress the part in the model state ā„–1 and at the same time it will be displayed in the model state ā„–2. In this area model statec is good for me.
But in BOM i see all parts: active and suppressed (i know that suppressed parts counts as 0). So in drawing of model state ā„–1 part list show all parts and I must to set invisibility by my hands.
This way is to heavy for assemblies of 100 parts and maybe I am on wrong way. So I'm wondering if there is another way to control the display of parts in the BOM and parts list.
johnsonshiue
Hi! Are the suppressed components showing as zero quantity in BOM and PartsList? If yes, it is indeed the behavior in 2022.
If you are seeing suppressed components showing non-zero quantity, either the assembly has migrated LOD (Master BOM) or there is a bug.
Many thanks!
Software Test Engineer
dimamazutaMMJ32
Yes, suppressed components are showing as zero quantity in BOM and PartList. If this is normal in 2022 is there a possibility to to remove the suppressed parts from the specification?
johnsonshiue
Hi! Unfortunately, the ability to hide entire suppressed component row in BOM and PartsList is not implemented.
Many thanks!
RStancescu
Hi Johnson
One more question regarding this subject.... If a component in an assembly has a "Simplified" model state and assembly has a Simplified model state, they can be linked. (that works fine)
For the part, I have a different description for the model state Simplified than the Master.
When I show the Parts List in the drawing for the assembly in the Master or Simplified, that part with model states only shows description for the master state even if I have a Simplified view of the assembly.
In the link bellow,
knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Inventor-Wha...
it says this:
Drawings
You can select a model state when creating a drawing view. A Parts List displays the selected model state members and their iProperties.
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Inve...
What am I doing wrong? The description is an iproperty for the part.
Thank you for your support.
radu
johnsonshiue
Hi Radu,
It should work as the Help described. It could be a bug or something was not set right. If possible, please share an example that exhibits the behavior. I would like to understand the behavior better.
Many thanks!
RStancescu
Hi Johnson,
Thank you for you rreply.
Iā€™m in vacation now; you can just create a new iam, with a new part with two model states; add the part to iam, link together the model states and check in a drawing when you switch a view from master to a state; I tested description si company as iproperties. The Parts List doesnā€™t update when view changes to a model state.
Cheers
radu
johnsonshiue
Hi Radu,
I just tried the workflow and it seems to work for me. The partslist will update based on the Model State selected in the view. After you change the Model State, you will get prompted if you want to update the partslist. Choose one of the two Yes'.
If it still does not work, please share the example after you come back from vacation. I would like to understand it better.
Many thanks!
darren.reynoldsCWR6V
Hi What I have been doing is firstly making the part a reference part before I suppress it it then does not appear in the parts BOM list.
dhaval.chauhanEUZNU
Observer
Observer
hello,
there is another way to filter to show only balloned item in part list, may be it will work for you.
Go to Bill of material > filter setting > definine filter item from drop down manu> Ballooned item only
MAKE THEM REFERENCE BEFORE YOU SUPPRESS THEM THAT WORKS
gbrisbinUZ9NP
I don't see why this is necessary, but it does work.
johnsonshiue
Hi! I think the Model States in the assembly are migrated LODs, right? If yes, the Model State BOM is delegated to the Primary Model State. This behavior is to ensure there would be no change to the migrated legacy drawing. If you want to leverage the new Model States BOM behaviors in such drawing, the migrated LOD will need to be deleted and recreated. Here is the procedure to do that
Copy the Model State to Design View -> delete the Model State -> copy the Design View to Model State.
Many thanks!
maulik_patel
Hi!
You may want to click on 'BOM setting' and check option for 'Hide Suppressed Component in BOM'.
Thank you
Maulik R Patel (maulikr.patel@autodesk.com)
SQA Engineer, Inventor
Autodesk, Inc.
dimamazutaMMJ32
It's not exactly what i had in that situation and i need to do additional manipulations, but the solution is suitable.
