BOM row merge not working in 2021
mikejones
mikejones
I have an assembly file where I need to separate out identical part numbers in the BOM. I've turned off the 'Enable row merge on part number match' but it's having no effect on the BOM; all identical part numbers are still grouping together and showing a total. This is the first time I've tried doing this in 2021 and the functionality seems broken now.
Any thoughts?
Mike
Autodesk Certified Professional
mdavis22569
Can you share the files?
2021.01 installed?
Mike Davis
mikejones
Here's a P&G zip file. Current build is 2021.0.1
This is happening on all assembly files now since moving to 2021 and not just this one assembly.
Mike
