BOM can only export the first level..
MatsNorway1
Message 1 of 11
MatsNorway1
I wish to export the entire BOM but i can only get the first level of the assembly. Why?
‌:nauseated_face: ‌:face_with_medical_mask: Fusion 360
Replies (10)
Message 2 of 11
mcgyvr
In the bom screen press the "View Options" button then "View Properties" and change "Level" to "All Levels" and set your delimiter as needed..
Message 3 of 11
MatsNorway1
There is no "view options" as i can see.
Message 4 of 11
SharkDesign
Where it says 'parts only' it says disabled. Right click that and enable.
Is that what you are after? Or do you still need it structured?
  Inventor Certified Professional
Message 5 of 11
Gabriel_Watson
Here (right-click Structured, then "view properties", and pick "all levels") :
Message 6 of 11
MatsNorway1
Jupp. That did it. Thanks
Message 7 of 11
johnsonshiue
Hi! You may want to change the same setting in the iam template you frequently use. Next time it will be enabled automatically.
Many thanks!
Software Test Engineer
Message 8 of 11
slawkidwa
Hi John
Is there a choice te export 2 or 3 levels of BOM structure?
Message 9 of 11
johnsonshiue
Hi! It is only first-level or all-level. You may not designate a particular level to export. You may need an iLogic rule to do such customized BOM export.
Many thanks!
Message 10 of 11
slawkidwa
Thank you Johnson.
Any AUTODESK's plans (improvement) for the future with this topic?
Message 11 of 11
johnsonshiue
Hi! Please feel free to submit it to Inventor Ideas(https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232).
Many thanks!
