Message 1 of 8
BOM assembly filename column is blank unless i remove filename column and re-add.
Every time I open a Bill of materials for an assembly the filename column in the model data tab is not populated with values. I have to de-select(remove) the filename colum and then re-add it again to see the filenames. Then if i close the BOM and re-open they are gone again!
For me this is the situation for every assembly/bom. I have attached a screenshot of what i see before and after removing/re-adding the filename column to the model data bom tab.
Does anyone else have this problem?
